Ridiculously basic question but i’m really struggling to constrain to axis and to the inference. If i just want to snap two surfaces together on an axis how do you do it. At the moment it’s fine along the axis and the minute it finds the edge it jumps the ends together. Constraining to axis doesn’t seem to work.
Also is there a global coordinate menu I’m missing?
Absolute coordinates would be great. I searched the user guide to no avail.
I’ve uploaded a model I have a lot of repeating geometry and I’m to move things along the x axis to but the end of other items. Even if I look from the top camera and constrain to the x the items jump all over the place when they come near an edge. I’m obviously doing something wrong.
When I open your attachment, all I see is the Marc figure and a circle on the green axis. No repeating geometry that I can see. Can you reload the file?
I see the same thing David report. Marc and one circle.
Start moving an enity and type [x,y,z] where x is the distance from the origin along the red axis, y is the distance along the green axis, and z is the distance along the blue axis.
No. There isn’t a way. You can see the absolute coordinates if you put leader text at an intersection or endpoint.
How would you use absolute coordinates in your modeling. In over 17 years of using SketchUp I’ve found no need for even knowing those coordinates in my own modeling. The only time I use them is when trying to help someone with a model they’ve screwed up.
One thing that jumps out at me immediately (And this is a common new-user mistake) is that you haven’t drawn out the circles for the round parts on axis. You can see that in this closeup view of the top of the vertical support. The guideline is parallel to the green axis and passes through the center of the circle. Best practice is to drag out the radius of circles on axis so the vertices will be in predictable locations.
Just having a basic problem aligning and moving stuff. For example I’d like to know exactly where the bottom of the nase component is or the scaffold. I’d like to move stuff to the edge of something else but in a different plane so it doesn’t touch. I know the coordinates but I can’t type them in so I have to drage stuff around and it goes everywhere aligning in my mind to what it fancies.
It sounds like what you really need is a lesson in using the Move tool and inferencing. Hang on a minute and let me catch up on stuff and I can show you.
If it had been dragged out on axis the vertices would have fallen on the guideline like they do in the screen shot after I rotated the geometry.
Clicking where you want to put something or moving it into place is just the way it is with SketchUp. Once you learn how to use Sketchup it becomes second nature.
