Are Warning symbols supposed to appear on PDF outputs?
I’m using LayOut 2022.
Here’s an example;
That warning means that you have to update the viewport cause the model was modified, just left click on the viewport and update reference, or on the sketchup model tray on the upper right corner click that kind of circle button, you can set it up so it makes that automatically and those warnings won’t be shown again.
To answer your question as phrased, I suspect having those show on the pdf export is an oversight. However, I think it is a good thing, as otherwise you might not realize you have exported a pdf from a model that is not properly synced!
