I’m having a problem with my graphic card, i think.
I already searched for everything in forums and nothing helped:
I tried every antialiasing configuration possible (in Sketchup Preferences)
I also tried every configuration in Nvidia Pannel (RTX 2070 8Gb)
I’ve already installed (and reinstalled) the last driver (Nvidia Studio, and Nvidia Gamming, just in case…and nothing)
I also reinstalled sketchup, and test older versions (i’m current using the 2020.3)
PS: i used to work in sketchup in a laptop with Nvidia GeForce GTX 960M 4Gb and it was nice, better than now with RTX 2070 8Gb - no sense at all.
Nothing seems to change, even when i change the antialiasing from “0” to “16”, or when i change any configuration in nvidia pannel…i’m pulling out my hairs over here…
All that and lines are still looking this way:
Please, any good soul, help before i became bald.
Thanks!
Just a random guess/idea… but can you check your monitor resolution is set to Native?
Are you on a laptop + external display?
Does it show the same jagged edges on any display you’ve tried connecting to?
I would set all Nvidia settings to default.
Also when uninstalling make sure to restart in between and , i fpossible, perform a “clean install” of the studio drivers.
Thanks @AK_SAM !
The problem is on my desktop…my laptop is running everything fine (with the GTX 960 that i mentioned)
But I aready did all that…setting Nvidia to default, “clean install”, restart the computer, sketchup, etc…
Same results…
