Yes, Steve - I was editing my previous post when you replied, and I see a roughly equivalent result.
Yet another of the many, many examples of poor modelling in the 3D Warehouse.
Advice, often repeated, for the OP - look for low poly count and low file size models in the 3D Warehouse, download each into a separate SU model file, and examine them before including in your main model.
If you are using a particular manufacturer’s Product, check that too. It may look like what you want to use, but many of them too are just converted from the product manufacturing CAD models, again with FAR more detail than is needed for the visual appearance you want in your main model.
PS. A closer look at the At Ease stool.
Upper frame top - rounded top not even properly joined to the side, and reversed, with FAR too many segments:
After removing the cushions (difficult without wrecking other parts of the model, because there’s no use of sub components) I see otherwise irrelevant details of the webbing. You can’t even SEE most of it with the cushions present, from any viewing angle you’d be likely to want to use for the whole model.
I haven’t time or inclination to fix this model. As DaveR often says, it’s easier to draw it again, using the same dimensions, and sometimes copying parts or even just faces from the old model (then pushpull).
If I were to do so, rather than (probably quicker) find a better one on 3D Warehouse, I’d make it with components like a real stool with cushions, and copy and/or mirror left and right back and front legs, and crosspieces.
Each piece made into a solid (in SU terms). Cushions redrawn with maybe 8 segments per semicircular arc, using FollowMe round a rectangle a little over 16" square and about 3 1/2" thick. (The originals are no particular size, and not square.)
The result would be visually virtually indistinguishable, and a fraction of the file size and edge count.
PPS. And something else I’ve just noticed in the stool component. 24 different tags, IGES0-23, applied to edges and faces.
Where did those come from? I’d delete all those tags, and reassign Untagged to all the edges and faces in the stool.
