I’ve had this happen many times to me. I have several rooms filled with furniture on my sketch up and when I try to zoom into the room, it jumps me into the middle of nowhere and I have to spend the next 5-10 minutes trying to find my rooms again… I have no idea where it sends me to. Could it be because my rooms aren’t on the ground even though they look like they are? How do I fix this!
It’s hard to say what’s going on exactly without seeing your model. Can you share it? If it’s too large a file to upload directly, upload it to Drop Box and share the link.
Uploading: Floor plan.skp… I’m having the same problem. I’m also unable to zoom in any closer than about 20m away. This is the first time I’ve experienced this and I need any help available. Thanks. 2019-06-15T12:00:00Z
You’ve stuck Brice way out along the green axis a long way from the rest of the model. This will create issues for you. Zoom Extents shows him out there. His banishment to the outer reaches of the kingdom can also cause you problems when you are zooming in on detailed parts of your model.
I think you could improve things considerably in your modeling if you would use layers to show different room arrangements while using the same walls. No need to make copies of each room to be able to show the different arrangements.
