I’ve been editing a document in SketchUp Make, and having enlarged part of it to make it easier I clicked on ‘Zoom Extents’ to shrink the model to full-page.
Instead I got an image reduced to almost invisibly small (some of the text was still just about distinguishable). There was an autosave, but alas it included the disastrous shrink. However, its file size of 13.7 MB suggests the information is all there. The file is a drawing of the top floor of my French house, about 100 m² in all.
Hi Dave, thanks for your reply!
I tried the orbit tool, to see if there was anything elsewhere in the picture. The image doesn’t rotate etc., whether or not I’ve done a ‘Select All’.
This is actually a recurrent problem, but this time I lost several hours work, and the autosave didn’t save me!
You can click individual parts of the model in the outliner you may be able to figure out which thing is a long way away (that’s totally going to be what it is!)
You could save a copy , then delete a bunch of things at a time, clicking zoom to extents until you narrow it down
Here you go. You had the Camera set to Parallel Projection and a couple of text entities at a huge distance from the rest of the model. I deleted those text entities and also fixed incorrect tag usage, purged unused stuff fro the model and zoomed extents to show your model.
BTW, you should be using groups and components for the geometry you create and you should make sure faces are correctly oriented. There should be no exposed blue back faces in your model.
Blimey! Brilliant, thank you so much!
I do use Groups quite a lot, but seldom Components.
Correctly oriented surfaces is a common problem for me – it takes time, but eventually I get them back together.
Who/what
are the exposed blue-black faces?
Hi Chip cookie. I came from 2-d, in the form of the wonderful Claris CAD, with which I designed a light aircraft, and won a prize from the Royal Aeronautical society! Since it disappeared I tried a few others, but none came close. I now use Graphic Converter for some pixel-editing work, but have never found a 2-D program which came close to Claris CAD.
Claris CAD was awesome. I wasn’t really thinking of a CAD program, but something like Omni Graffle. Visual Communication Software To Make Pro Diagrams - OmniGraffle - The Omni Group I made some custom bits and bobs and now use it for quick 2D sketches of parts clients want me to make. Basically converting their napkin drawings to something digital.
It disappeared in 1991, but you can use it by emulation. Sketchup is a lot better than Claris cad, you can design and model a 3D object and get 2D images out of it with LayOut, or exporting to any other Cad software.
