Hello!
I have used by accident “zoom extents” and I have no longer acces to my image.
Is it possibility to resolve this problem?
Untitled1.skp (1.9 MB)
Untitled1.skp (1.6 MB)
Here you go.
Thank you so much!
I think what has probably happened is that you had text attached to some object which you then deleted.
There’s a known bug that then cause the text to fly off to infinity, so when you then Zoom Extents, everything in the model goes very far away. .
Looks as if Dave has fixed it for you while I was typing, but you could learn to fix it yourself too.
I picked a random object in Outliner, and chose Right click - Zoom Selection.
That enabled me to see part of your model, and I then manually zoomed out to see it all.
There was a stray bit of text near the top of the window, which I deleted.
Zoom extents after that showed me your model very shrunk in the middle of the screen - smaller than this magnified view.
I window selected round that, then copied and pasted it into a new model, and then Zoom Extents showed properly.
I’ve seen Dave refer to a plugin he uses called Rescue My Model. He may have used that to recover your model.
Thank you for your that explanation. I hope I won’t make this again, I just have to understand it… but maybe it will be useful to someone:)
Often just going from room to room leaves me wondering what the plan was.
