Hi,
Why does the LenY value does not show the correct value?
Thanks in advance.
Hi,
Thanks in advance.
My component options are also not visible/shown in the dialog.
I opened up the Ruby console, and the problems where solved.
The first “child” (nested) component is an Auto Cut-&-Glue compo. That may be realigning the Origin and thus, throwing off the Axes Definitions.
fix the lost references and repost
I removed the glue, but still no success. I removed the lost references.
@pcmoor If you can check for me, thanks in advance!
Test.skp (245.8 KB)
For some reasons all my newly created dynamic components have the same problems.
I set the height 100cm and the result is 39.37007874015748 cm
I hope somebody can figure this out with me, so I can continue creating my models.
Post your component. Your formula converts your height value to inches. I don’t know if the “cm” at the end of your post was added by you.
What are your settings for the A01_height parameter? I would set it to be Centimeters and to display the end user’s units.
Is the “Display units format” box checked in your model’s Modei Info>Units dialog? An old. old, still standing bug causes non-inch length calculations to fail if it is not checked.
First is was set to text, if I set it to cm it will show correct in the attributes.
But the component options are not shown.
Restarting Sketchup seems to resolve the not showing option problem
I have some custom parameters which were set as text. Setting them correctly to cm solved the problem that the results was shown in inches.
Sketchup seems a little buggy. Sometimes the options are not visible and sketchup has to be restarted.
The same goes with placing a dynamic component not snapping to the right point on axis.
Restarting sketchup also solves this.
