Hi…
Please attached the file. The Highlighted areas/ Below mentioned formula throws wrong calculated value. ( For Frame_01)
The Frame_Right (Value LenZ), Frame_Left (Value LenZ) & Frame_Support_top ( Value Z)
If anyone let me know what is the mistake.
Wall_panel_02_4.skp (60.4 KB)
Hi there,
you simply haven’t defined the height of frame left, frame right has the definition…!
And thank you, I never knew the parent! funktion, where do I find these things?
@mkluth70 .,
The issue relates with the Frame_01
i am not getting this. My model has defined all formula’s
i learned that in the forum. Thanks to @pcmoor :). you observe his posts. Lot can be learned.
I took frame_01, here the Frame_Left has no definition/ formula for LenZ, on frame_02 it is defined…
But my source component, before Save As–> component has defined the formula. After saving only, the formula seems got deleted during saving (not defined).
I dont know is this a bug! Any fix?
I saved the corrected component and reopened it in another file…worked. So I can’t reproduce your issue
Ok. i got it by deleting the LenZ Variable and entered the formula afresh.
Thanks
