I organize my workspace, placing some tool palettes where I want them and switching some off. When I reopen SketchUp the ones I have switched off reappear all over the place. What can I do to keep my workspace looking the same at startup as it looked when I closed SketchUp?
I tried to get answers from SketchUp’s AI Assistant, but they were vague and not conclusive…
I am afraid this is not the case. I installed SketchUp correctly, in the Applications folder, and dragged it from there to the Dock. Thus there has to be another answer to my problem. Thanks, anyway.
When you say “tool pallets” are you talking about ones from extensions you have added to SketchUp? As opposed to native tool pallets? If so this is a common problem occurring with some extensions and is unfortunately not solvable by the user or by SketchUp. Each extension has the power to record and save it’s own to tool pallet visibility state, this is not a SketchUp code function. The well written extensions record their visibility state and will relaunch in a fresh SketchUp opening in the same state it closed in. Some extensions fail to record the toolbar state and default to “on” every time you open SketchUp. The solution if this is the case is to disable that extension.
I have some extensions I use that won’t save the toolbar state but I like their function, for these I keep them enabled but gather all the tool pallets in the center of the screen where I can close them quickly each time I open SketchUp.
Sorry, I meant palettes, not “pallets”. I did not know about the fact that some extensions do no not save the toolbar state. This is probably what is causing my problems. Thanks!
here you can see the limit between my 2 screens, and that my firefox window (right) is poking too far.
when you launch an app, it’s not allowed to put stuff into the safe zones. but when using the app, you can manually put stuff there.
meaning that if you have some toolbars or panels that are a bit outside of the screen area or too low next to the dock, on the next launch they’ll be moved. in my case, they tend to be moved to the other screen.
