Hi everyone, I have just started using SketchUp but unfortunately something is wrong with it. I have really bad quality image of my work space, tried changing AA options and other stuff but nothing helps. Any ideas?
Work space image issues - lines, glitches, artifacts
Thatâs a graphic card issue.
Try unticking Use Fast Feedback.
And/Or
Update the graphic card driver directly from the card site, donât leave it to windows to tell you it is up to date.
Did all of that before, no effect.
Looking at the AMD site, the newest driver for your graphics card is 15.7.1 WHQL. It is almost 5 years old. Check that you have that. Also, in the card 3D settings Antialiasing and Anisotopic filtering should be set to application controlled (or equivalent).
If that doesnât help you might be out of luck. Your GPU is definitely in the class of âlegacy hardwareâ. Does it have the required 1GB of graphics memory? It is one indicator, although the old, old Nvidia Quadro FX card in my older computer still works perfectly while having only 768 MB.
Note that after changing any settings in SketchUpâs Window menu>Preferences>OpenGL dialog, you have to quit and restart SketchUp before the changes take effect.
Of course I have these drivers installed. I did everything including restart of SketchUp after every change, every possible setting in AMD is set to application controlled, turned off and on all other options for tests, disabled and enabled dual graphics, disabled and enabled override. This âproblemâ is only in SketchUp. 3DsMax, Solidworks, Catia and some games like World of Warships run absolutely fine with no issues at all.
Besides current drivers and all settings, you might need to have the proper C++ distributables installed, as well. Perhaps you will need an older, I am not sure, but if you run the installer by right clicking on the installer file and choose âRun as Administratorâ the right distributables are be installed. (btw. it is preferred to install all software , including drivers, this way)
You do not need to remove first, just run the installer this way and when prompted, choose âRepairâ
Tried that as well as whole re installation, still the same. Guess Iâll have to use another laptop for Sketchup. Thank you all for advises and ideas.
