My model is only in wireframe, I can not get it back to normal. When I click on different style, it is still wireframe. How can I get it back?
Thank you,
Ryu
Thank you,
Ryu
Do you have layers in your model?
I have the same problem. It seems to be a bug where the style and axis do not update on scenes
Upload a model where this happens!
On the View menu, check the Face Style item - is Wireframe selected? Try selecting Shaded.
I do have layers
Wireframe bug.skp (3.5 MB)
I did, it is stuck to wireframe
Imported CAD files? You’ve hidden all the faces in the model. Turn on Hidden Geometry and they will show as grids. Not a bug.
Dave beat me to it by mere seconds!
There is a plugin at sketchucation called Unhide All that will unhide them all for you.
While you are getting the extension Box referred to, you should also get TIG’s Default Layer Geometry to fix the layer associations for the raw geometry.
I’d also note that the model contents are a seemingly unnecessary distance from the model origin - typical of import from CAD. That can cause issues in SketchUp.
Thank you my man!
Thanks!
This topic was automatically closed after 186 days. New replies are no longer allowed.
