Why is the grey area not selectable
They are not in the same plane. You should start from the beginning, work on a 1:1 scale and follow the tutorials of the beginner’s course, no matter how easy it seems to you to draw some lines.
wdi-05
In this new file { temp sketch 2.skp (75.1 KB) }
The grey face/outlines aren’t filled and it is also floating above the other surface.
You could redraw one line of the area so it can re-fill the area with a texture, or move the boundries so they touch the surface below?
not filled and floating
No, it doesn’t.
You must have done something to make it a group, SketchUp doesn’t do that by itself…
Edit: it is also possible that you made a copy of an existing group wich off course would automatically be a group…
Go to the campus and learn the basics before diving into the deep…
https://learn.sketchup.com/
After that you should go to the SketchUp channel on YouTube, search for the “square one” series…
The SketchUp You Tube Channel
