When I bring in an electrical symbol file that is a .skp into layout and then save it as a scrapbook, it is grouped for some reason, and I can’t explode it. when I open it in sketchup, they are all individual components. What am I missing?
A scrapbook entity from a SketchUp model will be a viewport when you drag it into a document. It could be that it was a group created from a SketchUp viewport and something else in LO but that has nothing to do with whether things are components in the model. If you don’t want it to be a group in LO, you can right click on it and choose Ungroup.
Where did you get that? It’s not set up to be used as a scarpbook. Someone stopped working on it before they were finished. I’ve spent more than an hour sort it out. It needs to have the viewports for the symbols in the lower section resized but I’ll leave that to you. Select the symbols above the large text to see what I mean. electric symbols scrapbook.layout (3.8 MB)
I believe it came from someone on this forum, I just had done a search for electric symbols for scrapbook. At any rate, I sure do appreciate you looking at it for me. I apologize that it has consumed so much of your time. I will look at the resize, thank you for your help it is above and beyond!
