What's the Plugins /Extensions install path for windows?
I’m using SketchUp Pro 2022 on Windows 11.
I have software (indigo renderer) which is looking for the appropriate folder to install its extension and related files. It doesn’t use an RBZ.
I tried the suggested path to no avail:
C:\UsersXXX\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Plugins
The extension installs okay into there but then is not available within SketchUp.
And I can’t find any other suggestions on SketchUp help pages
Managing Extensions | SketchUp Help
Cheers
Look here: Indigo for Windows | Indigo Renderer
Don’t fight the installer. Use its suggested default. Should be C:/Program Files/…
Thats the install for the Indigo program itself, which can be launched independent from SketchUp. It’s working fine.
Indigo also has a SketchUp extension called Skindigo which is, essentially, an exporter. There’s no default path given.
So did you restart SketchUp after installing it as you did?
Yes.
I found an RBZ download for an older version of Skindigo so I tried that using SketchUp’s manager to install it. Seems to be going fine.
