Weird view
I think my field of view is off or something I dont know what I did or how to change it. I want to go back to the default.
Barry Vaughns Dining room. 2.0 skp.skp (2.1 MB)
If you need to return to default field of view, tap z, then type 35 enter.
Thank you!
For future reference, if you hold down shift while zooming, you end up changing the field of view.
As a complement of information, after you select the Zoom Tool, you can enter a number followed by a press of the Enter key to set the fiel of view (FOV) in degrees.
You can repeat immediately with another number + Enter to try another FOV.
If you follow the number with mm (for millimeters) you can enter the focal length of the camera lens instead of the FOV.
