My FOV randomly changed and I can't get it back
Hello.
This is my first post here but I really can’t seem to figure this out. I have been working on a model and the FOV is super zoomed and this has never happened to me and I can’t seem to get it back to normal. I’ve tried using Z and nothing happens.
I also have scenes and even if I type in “35 degrees” and after press the scene it goes back to 97.98 (seems like this is the default?).
Note that I’ve worked on this model before and everything was normal.
My questions is how do I get this back to how it used to be (default).
Image for reference
the FOV is part of the infos that scenes keep.
if you change your FOV to 35 then click on a scene where it’s set at 97,98 then it’ll revert to that. and if you have another scene where it’s 42 then clicking on the scene tab will change de FOV again.
if you want to change the FOV of an existing scene, you have to go to the scene, change the FOV, adjust camera if needed, then update the scene.
update_scene
I can adjust the scene and set it to 35 degrees and save it but the whole vision of the model looks kinda deformed? Idk what it is but if i compare it to another file i have it just looks so weird.
(these are 2 different files but the model is very similar i tried to catch same angle quickly)
Image where view is normal
(i can only post 1 image per reply )
Image where view is weird
hello, to change the FOV without having to type an exact value, you can roughly modify it by holding shift while using the zoom tool (z), and slide your mouse up and down
I’ve tried that but im starting to think its not an FOV problem now but just how the camera looks
