Hello,
when i render with vray engine cpu and denoiser vray, the image turns out fine.
but when i render with vray engine rtx and denoiser Nvidia AI, the reflection in the mirror is black
plz help
Hello,
plz help
Your profile shows you have a Radeon GPU, not nVidia. Has that changed? Are you still using SketchUp 2017?
Your profile still says you have a Raeon graphics card. If you do,those settings in Vray won’t do you any good.
If you want help, how about actually answering my questions?
Does a GeForce GTX 1650 graphics card support RTX rendering?
Mine doesn’t.
That option will still work - it just won’t be using the RTx cores.
Optix is kinda like a newer version of CUDA.
The different render engines produce different results as they support different features cuda/optix(rtx) support fewer , so it may be that you are using something that isn’t giving you the result you want.find it and Turn it off or use CPU
