Hey,
I have a problem with sketchup for Vray. It seems to only be with this one Sketchup file and when I go to open asset editor or interative render, it says - the new version 6 is available and then it crashes sketchup with this msg. I tried purging the unused and even copying into a new model but it does the same thing. Any ideas please?
Did you install the new update?
Yes, I’ve installed the update
Did you send the data to the Chaos people as well - V-Ray for SketchUp - Chaos Forums?
Submit a request for help - https://support.chaos.com/hc/en-us/p/vray
You probably imported directly into the model in which you are working some component from 3D Warehouse that contained problematic geometry or texture.
Thankyou I will do that
I’m on the trial so can’t post there.
