Crash when using vray
An error occurs unconditionally when running vray in SketchUp.
Even after reinstalling, the error occurs
did you send the bugsplats ? using the same email you’re using on the forum ? if so, the devs can check and tell you what went wrong.
also, have you done what’s in the error panel ? sending the log to vrays team ? Problem might be sketchup related, or it might be vray, better contact both :wink:
you could also share your file with us here if you want another user to try it on their machine (to rule out a file issue)
