hi,
when i set cuda with Cpu+Gpu and i try interactive rendering, sketchup crashes.
this is the exception:
Firma problema:
Nome evento problema: APPCRASH
Nome applicazione: SketchUp.exe
Versione applicazione: 19.3.253.0
Timestamp applicazione: 5d9ca180
Nome modulo con errori: clr.dll
Versione modulo con errori: 4.7.2053.0
Timestamp modulo con errori: 58fa6d2a
Codice eccezione: c0000005
Offset eccezione: 000000000000dfd0
Versione SO: 6.1.7601.2.1.0.256.48
ID impostazioni locali: 1040
Informazioni aggiuntive 1: 0d05
Ulteriori informazioni 2: 0d0578e4fe29204d700fd17774163520
Ulteriori informazioni 3: 3b62
Ulteriori informazioni 4: 3b62b00c3d701019e7afd51417e87bd0
Which version of V-Ray? V-ray5 does not support Windows 7
Does it work with CPU rendering, and without the interactive option?
Do you get the BugSplat window, and have you added your e-mail and sent them in?
hi,
i’m using vray 5.it’s working on win 7.
i can use interactive rendering without problem with cpu, with cuda (gpu), but not not together.
BugSplat doesn’t appear, sketchup crashes and close everything and when start nothing.
According to the V-ray documentation, as said, V-ray requires Windows 8.1 or newer. This might be a reason why this happens. Maybe you have to do with “don’t do that, then”, as other render modes do work, and if you don’t want to try updating your OS.
