the interior is dark and the outside i am not to sure its correct could someone help
What program are you using to render your model?
Upload the SKP file so we can see exactly what youâve got.
thanks for the fast reply its vray i decided to start again from where i didnt put any lights or interiors in
na it says its too large
Put it in the 3D Warehouse and give us the link.
sorry how do you do that i am new to sketch up
could i send it to you via email
If you are trying to render with the global light (the âsunâ) then your interior will be all black. You likely need to add light sources, or remove a portion of your building so that the interior is affected by the light.
okay i will try
Yes you right but now how can i seal that up and still have lights in side
plus is there a way i can give my work a smooth gloss finish
yeah it worked now how can i get lights into the building pleas a simple and efficient way as i am a learner
I donât know. I donât use V-Ray⌠That probably something that you will want to reach out to Chaos Group forâŚ
okay where can i get them
I would suggest checking out their forum or contacting whoever it was that you purchased V-ray from.
hey do you have an easier way to put lights in interioriors using vray
No. I use Kerkythea. Itâs very easy to add interior lights it in. I donât use Vray.
Okay thank you
