Podrían volver a poner en la biblioteca de Sketchup la posibilidad de ir para atrás cuando estás buscando un objeto? es muy engorroso y poco práctico tener que empezar de nuevo con la búsqueda cuando no te interesa el objeto que estás mirando
Could you put the possibility of going back when you are looking for an object again in the Sketchup library? It is very cumbersome and not very practical to have to start again with the search when you are not interested in the object you are looking at
+1
the solution (since forever) is to use the 3d warehouse in your browser.
it has the advantage of not importing a 3d model straight in your project, reducing the risk of importing inadequate or bad models.
