Hi, I’m stacking two viewport, the fisrt one in raster (floor plan) and the one on top in vector (cabinet) and the vector viewport is not showing off transparent. It’s all white like it was still on raster mode. I do that all the time, no later then friday last week and it’s the firts time a experience this problem.
I cannot upload my layout file… I put a printscreen instead
Well, that’s an odd one. I couldn’t get rid of the background in your vieewport however after opening the SketchUp file and sending to a new LO file the background was not displayed. I then copied that viewport into your document and replaced the misbehaving one.
OMG! Thank you! Often just by clicking to change page in my tray the fill or stoke just turns on automatically and I dont know why. That must of happen here…
For the purge thing how did you do it. I do it by clicking on the arrow in each section of the tray. Sorry, dont really know how to explain in english…
I learned by myself so I still have a lot to learn…
That shouldn’t happen which makes me think there’s something else going on.
Purging from the individual trays isn’t a bad thing. Just do the Components before you purge Materials. You can also go to Window>Model Info>Statistics and click on Purge Unused. I use a plugin called Purge All to do that because it gives the report window so I can show how much stuff has been purged.
I also used a plugin to correct the tag usage for the raw geometry in the model. ALL edges and faces should be created and left Untagged. Only objects (groups and components) should get tags. It seems fairly common to get components from the 3D Warehouse in which the author hasn’t followed that rule and you inherit problems because of it.
