Hi, I am trying to hide the lines around a leaf component. It’s not my component. It is downloaded from the warehouse.
When I eventually work through the groups and double click to edit the component leaf, the position of the texture changes and completely screws up. Is there a way to stop this and why does it happen in the first place??? I have attached the model. It is small for once.
Mine too. more than 40 million edges. The more than 30 000 leaves have 150 entities each. The nesting makes for a small file size but doesn’t help performance at all. It is unusable.
To the groups and components from which the plant model is made need to be applied Scale Definition and Reset Skew, then you can edit them without changing the texture as soon as you open them.
But as you saw in the previous gif, you can hide all the edges without affecting the texture.
