I want to enter dimensions for a rectangle. To enter the dimensions I use a german QWERTZ keyboard. To separate the two different numbers I should use a semikolon. To get the semikolon (above the comma on the german keyboard) I must press the shift key. But every time (100%) I press the shift key sketchupmake 2017 crashes. I tried it with the german and the english version.
Perhaps somebody can help.
Windows 10 64bit
Firefox 51
Sketchupmake2016 is still working
In some locales the , is the decimal separator - rather than the normal .
So then the , cannot be used to separate values in the VCB - a ; must be used
So the ānormalā 1.2,3.4
must become 1,2;3,4
Unfortunately some localeās keyboards require shift-operations to get to a ; character, which can then break thingsā¦
Iām sure Trimble are working on the glitch as I typeā¦
Thanks TIG, thatās the reason.
And yes, in Germany the comma is the decimal separator. And because of that the X and Y numbers must be separated by a smicolon. And on a German keyboard the semicolon is on the key right to the āMā above the comma. And for that itās neccessary to use the shift key. And the help videos of sketchup show exactly this even for the english version. And it worked with the 2016 version.
And of course pressing the shift key should never splat !
And indeed, US/GB users need to press shift when typing feet and inches thus 1ā6" since in the US keyboard the ā is shifted-2 and in the UK keyboard " is shift-two [the two keys are swapped for some weird reason !]
You are of course right ! [At least with your MAC version ?]
I use a a PC UK keyboard and occasionally fall foul of computer sharing with USā¦
When our key presses are messed upā¦
But whatever keys they are, it still needs a āshiftā to get to one of them on either keyboard type!
I also think that the shift-3 for UK £ is actually # on US ?
What are on the key to the right of ./" in US - in UK itās #/~ !
Well thatās not good! No Iāve never heard of this shift key crash. Thomari, when it crashes, have you seen any ābugsplatā screens, asking you to send in your crash information?
And I have a German keyboard like described before, not a UK or US one and itās Windows.
The error appears if I press the left mouse button to draw a rectangle and release it. Then I want to enter the dimensions. I can enter numbers, but sketchup crashes if I press the shift key before or after a number .
Can you recreate this crash using other tools? How about these:
Rotated Rectangle tool
Scale Tool - scale from a corner grip, and press shift. Then input different scale values after the scaling is done - like 3,2;1,1:0,9 or something like that.
The rotate rectangle work
the Scale tool creates a crash just pressing the tool button
the save and save as create a crash too, after I entered the the name for the file and clicked the save button.
Perhaps itās a installation problem. Because I have had installed the pro version for just a few hours. Then I uninstalled this and installed the make version. And there is already the 2016 Make version installed. Perhaps there some entries were left in the registry or in the filesystem.
Thank you Stacy,
I uninstalled all 2017 Files and registry entries in ProgrammData, Programms, user Appdata Roaming and some places in the registry. Then I installed Sketchup again. The error came again.
Then I installed your recommended workaround and it works. So I think itās definitly the ATI-Problem. I read the workaround earlier at the forum website, but I couldnāt imagine, that it could be connected to the problem with the shift key, even the hint is in red color and highlighted.
Perhaps It would be a good idea to give some examples of errors at this place, which can be caused by the ATI problem. This could possibly save you some time helping users like me.
Hello Thomariā¦Good to hear you recieved help and all is working.
We also needed the semicolon in Denmark⦠butā¦
my solution was, to install āWindows Ultimate, English versionā.
Now my comma in the numeric pad works fine, as separation between values.
Other benefits is,that Window shortcuts also follow the english keyboardā¦
and I can use information directly from examples on the internetā¦
Andā¦
I train my englishā¦!
Hi Jakob Hovman,
I think the english version of Windows wouldnāt have solved the problem. Because the most important differences are the (silly) german umlauts (the vowels with the two dots obove), which cause a different keyboard layout. So a english keybord (physically and in Windows) would have solved the problem ā perhaps, but the better solution is the workaround because of the problems with the ATI graphics card respecticely the drivers.
