Updating Default Image Editor - Affinity Photo 2
Hi There, not sure if this is a new bug or affinity / Windows 10 / Sketchup incompatibility… but I cannot point my preference to the newly purchased Affinity 2 suite… it was simple before… just tracked down the executable in my program files and “choose” it…
af1
Now, when I track down the lastest Affinity Photo 2 exe… I find that it is no longer in “program files” but in WINDOWAPPS
The Problem is …
this is a protected folder and Sketchup preferences does not allow me to CHOOSE it
and I cannot manually type it into the Default Image Editor field…
I have no idea why W10 installed the executable in the WINDOWAPPS folder… I did a default Affinity Install… it has never done this before… and as you can see Affinity seems to be the only “non Microsoft” program there…
Of course I can work around this by bypassing the Default Image Editor call and edit the image outside of SU actions… but it seems to flag something more…
PS I am using SU 2021 still
Any thoughts?
hello,
apparently sketchup is not the only software having issues with this new hidden path.
you might want to try this, someone among their team managed to create a launcher that would fix the issue
https://forum.affinity.serif.com/index.php?/topic/170283-affinity-photo-v2-exe-file-location/&do=findComment&comment=983460
Thanks Paul… seems like an Affinity stuff up, still no fix after 3 months now it seems… even though “their programmers are working on it”
Was able as a temp fix to create the batch file on my desktop and choose it from the Default Image Editor preferences and that worked for the moment…
start /b affinityphoto2.exe %1
exit
place that in a batch file and name it what you want!
You’re actually pointing it at the wrong executable.
You want:
C:\Program Files\WindowsApps\SerifEuropeLtd.AffinityPhoto2_200.4.1701.0_x64__844sdzfcmm7k0\App\photo.exe
SketchUp will be able to open that.
For others who have a similar issue with the newer style MSIX or UWP type packages , which are usually installed via the Microsoft Store , this is how I found the link:
  • I ran the editor (affinity photo 2 in this case)
  • Pressed Ctrl+Shift+Esc to bring up the Windows Task manager
  • find the program you want in the list and expand it
  • then right click and choose “open file location”
This then takes you to the folder where the program’s executable is
copy and paste the address from the address bar , in my case :
and then add the name of the exe file you want on the end (\photo.exe)
e.g.
I was in the Affinity forums yesterday about this same issue. What is happening is the installer is a .msix file, from the Windows Store, is sandboxed. The batch file mentioned by @gsharp is a temporary fix that will break when the App is updated. The path referenced by @Elmtec-Adam cannot be accessed by the system. From the Affinity forum aflaunch.zip (Why are we using MSIX for Windows installers? - Frequently Asked Questions about V2 software - Affinity | Forum) is is in a post from Patrick Connor. I have also uploaded a copy of it
aflaunch.zip (9.7 KB)
Point the file preferences path to this file. I have verified it does work.
I tried it in SketchUp and it opened Affinity photo
Reviving this topic… does anyone have a fix for Affinity 3?
It would help if SketchUp didn’t require a link to an executable but would simply offer the same options as windows does when you choose ‘open with’, or simply use the windows default for the chosen filetype
hello, if you follow adam’s steps, it works just the same than with v2
open task manager once affinity 3 is running, right click, open file location, copy the affinity.exe path and paste it in the path editor :
and you’ll be able to select the .Exe file.
it does not work if you don’t paste the path as your system won’t let you browse the “windowsApps” folder
I guess it’ll be annoying since when I see the path, it means you’ll have to update it everytime a new version will be released
Thanks @paul.millet I guess I didn’t follow the instructions correctly the first time. It works now!
