rebuild the scene
Pada tanggal Sel, 19 Jul 2022 18.42, Dave via SketchUp Forum <notifications@sketchup.discoursemail.com> menulis:
rebuild the scene
Open the Components panel, drag your components in to the model space, and place them as needed. The groups and any loose geometry you might have had in the file will need to be recreated the way you created them the first time.
Colin, hi! Can you please try to recover my file, lost 7 hours of work in it, on a deadline. I tried changing the extension, but is still unexpected file format.
https://we.tl/t-dFzsmKgfpg
@colin Hi, me again! Just to ask if there’s any chance you could look at my files
I missed your post. As with most cases I only recovered components and materials, and nothing will appear in the scene. The recovered file is almost as big as the original file, which should mean there are some components in the In Model set that contain large chunks of the missing scene. Hopefully you will know which of the components are the bigger ones, and can drag those into the scene.
Here’s the recovered file:
thank you very much!
Hi, I’ve just had the same 'unexpected file format problem trying to open one of my Sketchup models. I see lots of other people have had the same problem -
was anyone able to sort it out?
Generally speaking, no. We still haven’t found steps to cause a file to be unreadable. Support tell us that a high percentage of corrupted files were ones being saved to a remote server or file sharing system, but even when we try doing that, files don’t get corrupted.
hi could you recover my file i can not open it the sketch up says unexpected fıle
ortaköy+villa±1.skp (9.2 MB)
I could only recover the components, the scene will be empty. Look in the Components tray to see if there are any components you can use.
ortaköy+villa±1_recovered.skp (2.4 MB)
Hello, I have the same problem with my project. Can somebody help? @colin
I have been working so long on this room
Hi can you help me with my file?
In order for Colin (or anyone else) to help, you need to share your SketchUp SKP file. Add it here to a new reply if the file is about 15MB or smaller. Otherwise, upload it to a file-sharing site such as DropBox or WeTransfer, make the permissions for the file public, and post a link to the file in a new reply.
hello, my files are not working almost 3 files are not opening, the same thing shows up once it’s loaded.
pls check and help @colin.
it’s really urgent pls help,
I’ve attached the file below:
I am on a slow connection at the moment. I set your file downloading, but will need to check it in the morning.
alright @colin,
thanks,
yash
Hello Mr. Collin, can you help me? I have the same trouble and I really need this file.
Here is the link of the file. Unfortunately I’ve already replaced the .skb file:( with .skp
I tried both files, and could only recover some components and materials. Look in the Components and Materials trays to see if there is anything useful.
It took a few attempts to download the file. Then I could only recover components and materials. Check the Components and Materials tray to see if there is anything useful.
please recover my component here Sketchup 2021, thank you so much.
