Hi all
I’ve drawn an open tread staircase in which I’ve used the Fredo round corner plugin to soften all edges. I can’t now position a texture on it, so is it possible to undo the round corners?
I did come across this but thought I’d ask in case there was any development before I set about re-drawing the staircase. Remove round corners (LibFredo6) in Sketchup
Cheers
Box
March 1, 2017, 5:00pm
2
Turn on Hidden Geometry and position the texture on one face and go from there.
DaveR
March 1, 2017, 5:01pm
3
As Cotty wrote, since the geometry is gone, you can’t really undo it (unless you hit Undo right after doing, of course).
You can still position the texture if you first expose the hidden geometry. Then you can right click on a single face and choose Texture>Position.
