Hi all. I’ve rounded off all edges of a worktop with Fredo6 Round Corner extension. I need the edges to be square against the walls. Is there a way of selecting some of the edges to reverse the bevelling?
Thank you Mihai. The second video looks very easy, I think this is a new version, so I will look for that one. ![]()
Fredo Corner is a different extension from Round Corner and requires a separate license.
Here’s a basic manual way of doing it using follow me and solid tools.
If the path is more complex you can always use Outershell or Union and then trim the ends.
It’s important think about the underlying geometry rather than thinking I have to reverse the tool that I used to make it.
@box if OP has access to solid tools they can just move the 2 sides that need the round over replaced beyond the face of the wall and use the wall to cut the counter away. No need to use follow me, just the move tool.
There are a great many ways to do things in sketchup…
True that is.
Thanks Dave. I’ll check it out.
Yes brilliant idea!
