SketchUp Tutorial – How to Create Rounded or Beveled Edges and Corners
In this SketchUp tutorial, we’ll show you how to create rounded or beveled edges and corners in SketchUp using a SketchUp extension called FredoCorner:
To use FredoCorner, you’ll need to download and install two extensions from SketchUcation.com:
  1. LibFredo6 - https://sketchup.school/libfredo6
  2. FredoCorner - https://sketchup.school/fredocorner
Be sure to watch and let me know if you have any feedback or questions!
I think you should be mentioning it is a Commercial Extension, just to avoid confusion.
And being a little pedantic, you actually need to install 3 extensions to use it. You must have the Sketchucation tool itself to manage the license or it won’t work. I mention this because it is possible to download and install the other two without the sketchucation tool.
Just in case someone misunderstands, I feel a need to point out that a sketchUcation membership and their plug-in shop extension are free. They are needed because they implement the license system.
Thanks for the feedback - good points and we’ll keep these in mind when it comes time to update the video.
Another good point - thanks for taking the time to send that over. Really appreciate it!
Hello, can not find anything similar in the history.
Hope that you will understand me. I need to lean faces of the letter around 35 degrees.
Simple scale doesn’t work for it :frowning:
Can anybody tell me if it’s possible to do this for example by FredoScale?
1
Follow Me tool
Offset and Move tools
Fredo JPP
I feel so stupid…I am not beginner :joy:. Mihai.s thank you so so much!!! And even more for 3 ways for it :blush: that’s the answer for my question.
Hi, I am a beginner and am trying to install sketchUcation in the Extension Warehouse but its saying it cant be found. Am I doing something wrong?
SketchUcation is its own website.
You can get the Sketchucation ExtensionStore tool here:
Download it to your computer and then, in SketchUp go to Extensions>Extension Manager and click on Install Extension. Navigate to where you saved the extension, select it, and click on Open.
Once you have it installed click on it and sign in with the credentials you used at Sketchucation. After that you can search for and install extensions from Sketchucation such as Round Corner and Fredo Corner.
