Unable to save out Style on SU2020.0.362 Mac version
Facing this error as below screen recording.
also the version retrieved from Sketchup.version is 20.0.362
Macbook Pro 16" 2019 model, Catalina 10.15.3
Folks, let me know if this is a bug :slight_smile:
I don’t think it’s a bug. I can save a style OK.
I still can’t… I’m saving out styles using SU2020 on Windows instead…
Well you have narrowed it down to a SU/Mac problem then. And it can’t be a bug if other SU/Mac users are not seeing it.
What extensions are you running?
Emmm, actually none except the standard ones like DC and Trimble Connect… fresh copy
I did not recognize this one:
Please explain all of the steps from opening the Styles Browser dialog, right up to you getting the error-message about being unable to save a selected Style out into a file.
What is the destination for the save Style ?
Is the default Styles folder set up in Preferences ?
Does it exist ?
Do you /SketchUp have permissions to write to that folder ?
What is the Style’s name ?
Is there a dialog to choose a destination folder ?
etc…
There’s lots you aren’t telling us…
Once I click on save style it didn’t prompt OpenPanel
Yes, I never changed as upon installation so it’s the default default
Does it exist ?
Yes it does exist
Yes, I’m running SketchUp as admin
Simple Style, I was trying to save out a default style as a new one
None.
Mike, it’s Aerilius Ruby Console+, another plugin this machine has is the TwinMotion DirectLink for SU
Well, I would start there. It could be a conflict of extensions.
Tried… not working I guess I’ll seek for an minor version upgrade for my SU…
I have the same problem in SketchUp Pro 2020 Spanish version, the error seems to appear in MAC. The same problem was presented in the 2019 version.
My OS: macOS High Sierra
the defaul folder
Is the default styles folder set in Preferences?
Yes it is the default folder
Does it exist ?
The style already existed, I modified it and I want to save the changes as a new style
Yes i am administrator
Boceto a mano
I already use the rubi script to disable all plugins and the issue continuous
Can you save the style as I show below? You need to have style thumbnails displayed.
Noup, the issue continues, but I use MAC and you seem to use Windows
I do use Windows but the same process should work on Mac
I wrote the following in my previous post. You didn’t do that, though.
You are right it works that way !!! with the thumbnails selected. I was even able to do it with the same workflow that I was trying to do before. “right click and select save”
Thanks !!!
In summary,
SU Team is a bug, if you change the view of the styles to the list, and try to save a style it gives an error.
Thank you for the solution…
Sketchup … seriously!!
