Hello,
I am looking for a way for dotted hidden geometry lines to be shown as solid lines.
I discovered that I can “simply” select my object, right-click and select “show”.
But workflow-wise I cannot do this with all objects… it’ll take too long.
I imported the cabinets from another program. All the feet of the cabinets belong to the hidden geometry and are therefore dotted lines. Since I normally import at least 10 cabinats á 4 feet for a project, it is too much work to single-click on every foot. Is there a way to show all dotted lines as solid lines at once?
Thanks a lot in advance for your help!
Attached is my sketch up file. The one front right foot on the right is how I want it to be.
Do you import the same cabinets for your projects or are they always custom cabinets. If this cabinet, for example, will be reused, once you’ve cleaned it up, it would be a good idea to save it as a component in a local collection so you don’t have to clean it up the next time you want to use it.
Thank you for the quick reply + video!
When I right click I do not have the option to “deep select”… There must be something wrong with my setup?
I use the German program “Horatec” which has the opportunity to export to SketchUp.
All cabinets are custom-made and therefore I barely use the exact same one twice.
