Hi folks. I am trying to chamfer the end of a rod in Sketchup. I draw a circle on the base plane. I use the push/pull tool to make my rod. Now I want to turn the tip into a chamfer.
The help tells me to choose the move tool and click Command (on Mac) and select an end point on the circle at the end of the rod. I do this with moving the move tool and expect to see the tip tapering inwards. Instead, the rod grows in length.
I created an inner rod using the offset tool but manipulating that only moves it up and down, no chamfering effect there either.
I’ve looked at the preferences for drawing and change most things to see if that makes a difference and of course it doesn’t.
Any clues?
I’ll add my model file. It’s the rod near the right of screen.
Cheers.
Training #10.skp (2.7 MB)
