I would like to know how to do a chamfer on a circle.
Check the screenshot here :
What i would is to create a chamfer on the top of the actual holes in the plate, the goal is to install a countersunk screw.
What i did, i have ty to insert a inveresed cone on each holes, and then, i have try to use the “intersect” option, but i’m not sure how to proceed because sketchup don’t react as the quick youtube movies i can watch…
Can you help to give me an information step by step.
You could continue with the method you’ve started and use Intersect Faces and the Eraser to cut away the waste. Then correct the face orientation. There is an easier way. I’ll make a quick GIF. Hang on.
