I create something in SUPro and when I save it as a DXF and my CNC operator opens it in his Vectric program, my dimensions have been altered?
Any Help!?
There are some possible reasons:
- If you export a 2D DWG or DXF file, your camera must be set to Parallel Projection and your view point to a standard view (top, front,…) for the export to be to scale
- SketchUp exports using the units you are currently using. The receiving application should be set to use the same units when importing - automatic unit detection does not always work.
Note that even if you are exporting a simple flat path for a CNC cutter, exporting as a 3D model might give better results, as in 3D exports arcs and circles are retained, whereas a 2D export breaks everything to straight segments.
Anssi
Anssi-
Thanks so much!
That helped get us in the right direction.
