I exported a DAE file from SketchUp. When I view the dae file in the Autodesk FBX viewer it looks fine. But then when I use the Autodesk FBX converter, it creates the FBX file but nothing is there. When I view the FBX file in the FBX viewer, it’s empty.
When I did a quick test earlier I found the square face I made was not textured in the FBX viewer, after converting. I took it into Unity and found it was blank there too, but if I looked underneath the texture was there.
So, is seems like if you put a texture on a face that is reversed, it won’t be seen in the FBX viewer. I did another test where I made sure the front face was on top, and then that one showed up correctly in FBX viewer.
The same model exported as FBX was invisible when looked at with the FBX viewer.
I dont have the pro version anymore, but when I did, exporting as fbx gave me problems like not exporting with texture. When I export the dae it looks correct. Just trying to convert to fbx and have it actually appear.
Thats weird, I can view the textures fine if I view the dae in autodesk fbx viewer. Which options should I have checked and unchecked when I export the dae?
My exports are usually into CAD formats so I don’t have much experience about DAE.
This is how the default DAE export settings look like in my computer:
“Two-Sided faces” is an option that doubles your model size. It is useful only if you export a model that must have both sides of a face visible (like a flag, for instance) to an application that doesn’t support the display of back sides of faces.
The “Triangulate” option might have a big difference to whether an application can process the DAE file, as not all support faces with more than three vertices, so if an application cannot open or display your file, thia would be one of the first options to test.
If you check the “Export texture maps” option SketchUp creates a folder with the same name as your exported file, and puts copies of all your texture images there. If you move the DAE file elsewhere without the texture folder, applications you use to open the DAE won’t find the images.
