Trays not showing
Whenever I open Sketchup 2025 , only my default tray is showing, all my handmade trays for components, styles etc. are not showing and I have to click " window " - show tray - and reposition the trays everytime I open Sketchup. Even in files I worked on and saved them. And yes I got 3 monitors and the trays are on the second.
Hello, first make sure you don’t open multiple instances of SketchUp opened before modifying your workspace (if you modify your workspace in an instance and close it first, the second (or following) that will be closed last will reset any modification made
If you only have one instance running, modify your workspace and once done, save your model, even empty, anywhere with any name, close SketchUp and launch again and see if it’s ok ?
Hi P:aul,
thanks for the fast answer. I tried it now again, but no , trays are not showing , not even the 2 I got on the main screen .
All trays are not shown, only the default one , which I told to hide before I saved the file.
ASll other trays are hidden and I have to click " show tray " , but they don’t show where I placed them, they pop up in the middle of my main screen.
Cheers
dirk
perhaps they are not meant to be spread (on windows) just like it used to be in old sketchup versions. Honestly even If I have multiple screens at work, I just pined them inside sketchup workspace and their position is saved alright. some of them are auto-hidden and shown on demand
Not at work to try things out, sorry, lonely screen at home :slight_smile:
Here in July - I have been having the same issue since I got 2025 a few weeks back.
Reboot computer if you’ve run SketchUp this session.
Rerun the SketchUp installer via right-click “Run as administrator”.
Choose the Repair option.
When done Reboot computer again.
Open SketchUp with a blank Trimble-made template.
Do not modify the model.
If trays are closed, open and rearrange them as desired.
Open and arrange any extension toolbars as desired.
Close SketchUp (so that the GUI changes are saved into the "PrivatePreferences" file.)
