As you can see, the trees on the right are cut off by the fence texture. If I explode the trees I can see them through the fence texture just fine, but I’d like to keep them constantly facing me. Can I fix this? I’m using the latest version of Sketchup Pro 2018 on Windows 10.
Very likely it’s your “Some Garbage” graphics card. It works fine for me with SU2018 and the Nvidia card in my computer.
I see. I’m currently using a Surface Pro m3 to edit the model. I’ll have to check it at home on my GTX 970 and see if I still have the same problem. Thank you.
The GPU on this computer is a GTX970. I would hope you would see the same sort of thing.
Have you tried setting the “Transparency quality” to “Nicer” in the Styles>Edit>Face Settings tray?
That’s a good suggestion. Mine is set to Faster but maybe on the Surface Pro, Nicer would work better.
