@joao.p.arq Good question. This lesson was not intended to be a precise grading exercise. See attached for metric conversion. The goal is to have a consistent slope between each major zone. Of course in the real world we may need to include things like ADA (in the USA) landings, handrails, etc.
Here are the landings for you in Metric if helpful.
And don’t worry about specific dimensions. I was demonstrating how to draw vertical ‘spot’ elevations in the event you needed your ramp to hit at specific points but like I said, for this demo, it’s not important. Instead, try drawing a straight ramp from edge to edge and use the sandbox drape, or intersect with selection method (shown below) to get the exact curve/shape of each ramp.
example of flat ramp needing to get up to next level (0.9m above)
Much appreciated for taking the time give that information.
I don’t quite know why I haven’t changed to Metric yet. Must be cause the majority of youtube tutorials are North American.
Anyway, let me apologize for you going over that trouble, given that I eye-balled it and I think that I managed a fairly positive result. I was getting some weird twists and descents near the end of the slopes - particularly with the smaller walks - but a few measurement tweaks and it looked better.
I’m following the course and got to the dwg import. Sketchup crashes every time I try to import the CC_DesignBase.dwg file. It crashes right after I close the import results window. I’ve tried several different times with different settings in the options dialog and it crashes every time. Any ideas to get this to work??
Sorry you’re having that problem. I’ve saw a similar crash recently myself. Let me look further into and see where the problem lies as it has been working fine up until now. I’ll report back.
Do you by chance have V-Ray NEXT Update 2 installed? I’m trying to narrow it down to an extension as I’m getting reports from others the file opens fine…and like I said, I know a few months ago it was perfect some something changed recently.
FYI - I narrowed it down to the Skatter plugin that was causing Sketchup to crash when trying to import a dwg. Do you know how to notify them that their plugin is causing that issue?
Glad you got it working. I disabled all my plugins and my CAD import works now but hadn’t made the connection to which extension yet was the culprit. I’ll reach out to Skatter developer and see if they know what they problem is.
Doing the modelling rocks step and I wish to know what and why this occurs. When you’re drawing free hand - on this specific purpose - the line fades away you end up with weird surfaces, or none at all.
But when I draw outside of the model, I get the drawing just fine.
Edit: Additionally, I’m having some trouble with Fredo6 round corner. I either cause a warning telling the 2" offset is too large or “An error occurred in the Ruby code”
I’m not sure why it works outside of the group instead of inside of it. Try drawing on the outside…and then copy your rock outlines and ‘paste-in-place’ inside the group to get them back in position.
For RoundCorner, have you tried Fredo’s newer ‘FredoCorner’? That may work better than his previous extensions.
Hi @SunRay - Can you post a screenshot of the wall/curb that is giving you trouble? Some of the walls are made by using the Move tool as the intent is to slope the top of wall. If you’re getting that
message, it’s likely that a non-coplaner surface has been introduced somehow. PushPull cannot work on surfaces that are not ‘flat’. Once I see specifically where your problem lies I can help further.
