Hi,
trying to make these solid to intersect. can someone share how to make it solid?
here’s the sketchup file.thks in advance ![]()
Component_1.skp (126.3 KB)
Hi,
Are both the objects either a group or component? Each must be one or the other - loose geometry cannot be a solid.
The left object has reversed faces which won’t help. Correct that.
Does Entity info report both as Solids?
Have you tried running TIG’s Solid inspector2 plugin?
Not at my computer, so can’t try now myself.
Done. Check out “Solid Inspector” in the extensions warehouse.
Component_1.skp (133.2 KB)
The shape on the left in your screen shot isn’t solid due to internal faces. You can temporarily hide the flat face on top and delete those internal faces.
Also, you need to correct the face orientation. The blue faces should be on the inside. White faces should be outside.
Did you intentionally draw these up on edge?
hi john,
i didnt check on entity report - i felt i dont understood what it say.
ok. will install solid inspector
Hi DaveR,
how i draw the shape is ( i think it’s a longer unthordox process)
