Tips for modeling a fluid wall like this?
Tips or tricks? Anyone done something like this before in Sketchup or am I better off using a different program? example here
It could be modeled in SketchUp but it would result in a lot of geometry that could cause a big performance hit. Modeling it in another program could also be done but if you import it into SketchUp, you still wind up with a lot of geometry.
How will you use it once it’s modeled? Maybe a texture would work instead.
If I were going to model something like that wall, I’d probably use ClothWorks to do it.
It’s for a rendering. It needs to look as realistic as possible - i don’t think a texture would capture the light and color and shapes.
With Curve Maker Bezier Spline and Curviloft
sha-03
You show the Bezier Spline toolset which is a good option. I don’t see any use of Curve Maker.
Today I was working with Curve Maker and it stuck in my mind
Thanks, Dave, for correcting me!
You can perfectly do the same with the ‘Sandbox’ tools
