My preferred way of learning is hands-on. If I have a specific goal in mind, then I tend to learn better by trying to actually build that.
For a long time, I’ve been messing around trying to create a mobile “planter wall” for my wife to hide the trash cans in the driveway. I’ve gone through a lot of tutorials so I feel like I have a decent grasp of basics and I’ve learned a ton by playing around, but I have to believe there are easier ways of creating what basically comes down to a box on wheels and a frame to hold lattice.
Creating a box of 1/2" plywood is fairly straight-forward, although I still struggle with how to make changes to individual pieces once I’ve “joined” them together to make a box. For example, originally I thought I’d use 4x4s as the legs. The back legs go all the way to the top of the box while the front legs only go to the bottom panel of the box. Once I did that, I thought that it would be nice to “notch” the back 4x4s so they are cut in half diagonally from the bottom of the box “floor” up to the edge of the box.
As you can see from screen shot, even though I drew the line on the top face of the 4x4 I still can’t just select the part of the face that’s enclosed by the new line. It still selects the whole face.
I run into the same problem if I want to make a triangular opening in front corners of bottom so that the notched piece of front leg will fit through it. But I run into the same issue with that as above. Any tips/tricks on how to do that correctly?
The other 2 issues I’m having are:
Easier way to build a lattice component. What I did was create a separate file where I created a vertical piece of wood, then copied it x times, rotate everything 45 degrees, draw lines to make a box of the final size of the lattice and lastly push the faces outside of the box to the width of the pieces so all that’s left are the pieces inside the lines. Then I copy that whole component into the main model file.
How to push/pull components in a diagonal direction. I decided I wanted the wall to be higher, but the only way I can push/pull the ends of each diagonal piece is in one of the axis directions. The only thing I can think of is to go through the whole process, described in the above bullet, again.
I’ve attached the 2 files in case that helps. Thanks in advance for any assistance. I realize that everyone is doing this on a volunteer basis so I really, really appreciate the help.
TrashCanWall03.skp (3.8 MB) TrashCanWall Lattice.skp (50.4 KB)
