If you open the Extensions Manager dialog and choose the Manage tab and scroll the list, as any extensions slated for an update ?
Revit Importer for SketchUp
Sandbox Tools
Trimble Connect
Trimble Scan Essentials for SketchUp
Some of these extensions ship with the SketchUp [2023] installation and were therefore maybe updated with v2024’s release.
If you could try the update[s] and close SketchUp, and then try replacing the shipped_extensions version[s] in the Program SketchUp folder with the newer one[s] - SketchUp copies/loads from the shipped_subfolder - so that then your Plugins folder might then have the ‘newer’ version[s] copied over at startup…
In addition to TIG’s suggestions you might try repairing the SketchUp installation. Close SketchUp, find the downloaded installer, right click on it, choose Run as adminsistrator and then Repair. After that, a cold reboot and then open SketchUp again. Any change?
Thank you for your reply. I found “uninstaller_helper” but haven’t found any other file that has to do with install. Are you saying I should uninstall and then re-install SketchUp?
No! What I wrote is to find the downloaded installer. That’s the file you downloaded so that you could install SketchUp. It ought to be in your Downloads folder or you can get it again from Download All | SketchUp | SketchUp Once you’ve found it, right click on it and choose Run as administrator and then Repair not Uninstall.
