The measurements in SketchUp are different from those in Layout
. does anyone have any idea how to fix this? Very strange.
Check the image,
ow from here…
Share the LayOut file so we have some hope of helping you.
Sorry could find the new way to upload it, i just found it.
Plan V1 Guy 2026 --(LAVALLEE-RABY F-33 Ste-marthe-sur-le-lac).layout (6.2 MB)
If this can help.
There is another one, same line i just flip it for vertical to horizontal and mesure it
The bug (if) only append on the vertical line, i take the same line , change the orientation, copy the cotation in layout turn it and mesure the horizontal line and its ok but not on the vertical one.
Got it, it was a camera setting in layout,
i did a reset all on the camera and it turn ok.
Sorry. I got called away from my computer. I did see that you had overridden the scene Camera properties in LO. That’s generally not a good idea. It’s the cause of a number of problems.
I also noticed that the image is placed at a fairly great distance from the origin. You should keep it close to the origin to avoid graphical problems.
Glad you got it sorted.
