I have made any own textile folder in Sketch Up 2016 pro, to use in different files on different models. All the texture scale were correct on the first file I used them on and then on the first component I added them two in the second file.
However when I started adding them to the other components in the second file, all of a sudden the texture was far too small. If I edit the texture, the scales and dimensions are still the same.
Please help …
*just noticed as well, If i increase the dimensions of the texture to the right size on the second component, the texture is then far far too big on the first component.
why is the texture scale different for each component??
If I select ‘make texture unique’, the text then returns to the correct dimensions. But I cant do this for every single face.
