Hi everyone ! My SketchUp textures are not showing up. When I click on Landscaping, all the textures are only displayed in basic colors but I can’t see, for example, grass or leaves. In contrast, when I click on Wood, everything displays normally.
Have you ever experienced the same problem please?
Thanks !
Two common reasons for this.
Face style is set to Shaded instead of Shaded with textures.
The model is created much larger than it should be. Check known dimensions in the model.
Share the .skp file so we can see what you’ve got and the fix will be easy enough to sort out.
Hi !
Thanks a lot for your answer !
I checked it but even when i’m creating a new sketchup file, I don’t see some textures.
here are the links :
app.sketchup.com/app?3dwid=32fbb3c3-bfc0-4aa8-bcf5-0369c97392df
Thanks !!
I have this issue also, I realised I had started the design using the the wrong size format, I have resized the model but the textures will still not show. What can I do?
How did you resize the model? Did you resize the whole model in one go? Did you correct the scale for the component definitions? If you share the model it will be easier to give you direction.
BTW, please corect your forum profile. “mac OS 14.4.1 (23E224)” is the operating system, not “2024”. And that does not identify the graphics card. Please put that in your profile.
Hi Dave,
Yes re sized whole model in one go. Not sure the scale for component definitions have been changed or how I do that. Link below has the file in.
https://www.dropbox.com/t/eCnILAmlPv95nkbI
I will update my profile
Are you sure this is the right model? The only things I see in it with a texture is the cube component and the skylights?
You can reset the texture size on the cube by showing the hidden geometry so you can select a single face to reset the position.
For the skylights the easiest thing would be to explode the group and immediately remake it. The same would apply for the other groups before you add any materials… I did that to the roof here:
Much of the geometry of the roof is showing the blue back faces. Those need to be corrected. You should not have any visible blue back faces in the model.
Frankly, this model is simple enough, I would suggest starting over and make things the correct size from the beginning. Also get all of the geometry sorted out correctly before you start applying materials to the faces.
Thank you
