I want to edit the direction of the texture. But there is no texture on the right click of the mouse.
That’s like you had filled it with a color. If it was a texture, which one was it?
The surface is not a single face. Expose Hidden Geometry and then right click on a single face to orient the texture. Once you’ve done that you can sample its orientation and apply it to the other faces.
The material with the tecture might be applied to the containing group/component, not the face itself. If that is the case you can change the axes of the container to match the face and the material will be aligned to it.
