I can’t seem to find the option to edit the orientation for a texture - when I right click a face the menu that pops up doesn’t have edit as an option:
You’ll only get the Texture Position entry if the texture is applied to the faces inside the group or component AND you’ve only got one face highlighted. If you have the texture applied to the faces, turn on Hidden Geometry and check to see if your surfaces is divided into several smaller faces.
Or share the .skp file so we can have a look.
Simply stated:. You can’t edit a texture that’s been applied to a group or component as a whole.
It took me a while to figure this out. It’s quicker to apply materials to a group or component with the caviot of not being able to edit the texture.
Your call as to what you need.
