I have yet another question regarding Layout… I would like to design or use a Text box in my plans and I am wondering how to go about using the scrapbook tool to do, if it can be done…
You could create the balloons and add a text box to it. I guess I’d group the balloon and the text box and probably add some sample text that you can edit.
You could draw those balloon shapes in LayOut or SketchUp or you could import images of the individual balloons. to use. If you use images, I would make PNGs with transparent backgrounds.
It really isn’t terribly complicated. I inserted the image you supplied into LO and used the 2-point Arc tool to trace the first balloon. Then I glued the arcs together and used Offset for the inner dashed edges which I changed to white. I sampled the color of the balloon in the image with the eye dropper in the Colors window and used that color for the fill in the balloon.
That’s what I did for that one. After you’re finished with the image, delete it. If you are creating multiple text balloons to show in a single scrapbook page, move them all close together. Maybe in two columns. Then set the paper size to closely fit around the the balloons. When you save the file as a scrapbook, the balloons will be easier to see in the Scrapbook window. You can even overlap them slightly so they are more compact in the scrapbook.
You need to make sure the ends of the curves meet. Turn off Grid Snapping in the Arrange menu. And zoom in close enough so your bubble fills the window.
Ok my last question of the day is I inserted a sample txt writing into the cloud but it didn’t carry over into the scrapbook section, I just have the cloud and no text
Just as an aside, Windows has a nifty screenshot tool called the Snipping Tool in the Accessories folder in Start menu. It is easier to use it and paste the result directly into the forum reply window than to move over image files from your phone or camera.
